dash instrument cluster
155,415 MILES • 4.6L • V8 • 4WD • AUTOMATIC
GARY KREBS
  • 10 POSTS
Lost tachometer and speedometer function on original cluster (my bad). received used cluster, everything works except starting codes need to be changed to match my original keys. Will I have any problems getting my local Ford dealer to change the code for me? The Chrysler electric friend that checked out the used cluster for me said I might have a problem with Ford because of my used part.
Thank You, G.
Oct 19, 2017 at 5:38 AM
  • 55,561 POSTS
No you should be fine, just tell them what you need and they will program it for you.
Cheers, Ken
Oct 20, 2017 at 6:42 AM
GARY KREBS
  • 10 POSTS
Thank you very much, all this to replace a bulb, I open it up farther than necessary and detached the needles from there drivers. Thank you again. G.
Oct 20, 2017 at 8:04 AM
  • 55,561 POSTS
Please use 2CarPros anytime we are here to help.
Cheers, Ken
Oct 20, 2017 at 1:34 PM
