Dash information center not working?
186,000 MILES • 4 CYL • 4WD • AUTOMATIC
STXHAMMER
  • 47 POSTS
I have noticed the left side of my dash information center does not illuminate but I hear a beep or ding sound sometimes and I’m assuming it’s that side. Is it a fuse? Picture included for reference.
Nov 4, 2023 at 5:05 PM
  • 55,743 POSTS
I have seen the cluster go out and cause this, but we should check the fuses first. This guide can help, and I have included the fuse location in the images below for clarification. Please check the fuses with the key on.
If the fuses are good, you should do a CAN scan which will help you by showing the codes.
You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is how to change out the cluster, you can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Please let us know what happens.
Nov 5, 2023 at 4:05 AM
STXHAMMER
  • 47 POSTS
Which fuse would it be? Number 14 under the hood?
Nov 5, 2023 at 2:40 PM
  • 55,743 POSTS
Please turn the key on and check them all. Takes 2 minutes.
Nov 6, 2023 at 12:33 AM
