Dash color
140,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
CANDO1
  • 47 POSTS
I have a two tone dashboard
One is SEM 17413 Classic Coat For GM Light Cashmere
The Top half of he dashboard and steering wheel is darker tan. I want to recondition the steering wheel however I do not know the color used or where to find it in my cars codes. This picture is the color if it helps. I got the SEM 17413 to touch up the interior I need the other color so I can do the steering wheel.. It's a pretty common combination. Thanks
Mar 11, 2021 at 2:09 AM
Looks like that color is called Medium Dark Cashmere. Here is a link to a website that seems like it will match it:
https://touchupdirect.com/touch-up-paint/cadillac/sts/#pf-year=2008
If this does not work then the only other recourse is contact the dealer and ask they run your VIN and have them look up a replacement steering wheel so they can tell you the color. Basically they need to act like you are going to replace the steering wheel and they should be able to tell you what the color is called because the replacement will come the same color.
Mar 12, 2021 at 2:16 AM
