I Flushed and bled my brakes but still have slight spongy pedal and the dash warning light is always on when ignition is on. The pedal does not go all the way to the floor but stops okay when applied past the top third. Perhaps I need to re-bleed again to make sure there is no air in the system but not sure how to get the warning light to go out. New pads all around. How do you equalize pressure in both systems?
Thank you
Thank you
Dec 6, 2023 at 1:23 PM
