dash brake light on will not go off
100,000 MILES • 3.3L • 6 CYL • FWD • AUTOMATIC
OLDCATJR
I have a dash brake light that stays on checked parking brake switch and blocked it. also changed the brake pedal switch. How many other switches are in this dash brake light?
Jul 24, 2017 at 3:45 AM
HMAC300
  • 48,601 POSTS
if it says brake it may be an ABS unit problem and will need scanning by a mechanic with his scanner to find the problem. Some vehicles just use one brake light for parking and ABS. See link.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Jul 24, 2017 at 5:14 AM
WRENCHTECH
  • 20,760 POSTS
Have you checked the brake fluid level? That will also put the light on if it is low.
Jul 24, 2017 at 7:41 AM
