Dash board lights on
53,300 MILES
EMEJIAS529
The ABS ,Central waring light, automatic transmission fault indicator,brake light and traction control system off indicator all remain on. The radio does not turn on. When transmission is engaged in drive, the car does not move freely, you have to press the gas pedal firmly and this doesn't even get the car to move. It's almost feels as there some holding the car from driving. Please advise help!
Apr 13, 2013 at 10:42 PM
you need to have the abs code pulled to see what has failed. most likely a wheels speed sensor. once it is repaireed the abe and trac light will go out on its own. see if the trans light goes as well
Apr 13, 2013 at 10:51 PM
