Aug 2024 connected OBD2 scanner from AutoZone to check 'EC' code (been on 5+ yrs), no related issues with car driving, connection np, got codes.
Mar 22, 2025 new issues arrived (dash gas gauge floating around) tried to use AutoZone OBD2 scanner, connected to cars OBD2 port, scanner does not come on.
How can I check the OBD2 port? No, I don't have a voltmeter. I saw from the web the slot on the OBD2 port to check would be the top left row, first slot or number '16' slot for power?
Is '25' the right fuse for the audio/radio on the inside fuse box?
Thanks in advance ... Ernest here in Virginia Beach, VA
Mar 21, 2025 at 7:43 PM
