Dash and running lights switch not working properly
150,000 MILES • 2.9L • 6 CYL • 2WD • MANUAL
MAMACOUCH1998
  • 5 POSTS
When I pull my switch on halfway, the dash and running lights all come on, but when I pull the switch out all the way to turn the headlights on, the dash and running lights go off. Is this just a bad switch or a bad connection?
Feb 20, 2022 at 9:30 AM
I would first and foremost think the switch is the issue.
I have seen this a number of times over the years, and it normally is a switch issue. So, to confirm this we need to check the voltage coming from the switch in both positions on each of the wires.
Basically, what I suspect is happening is the contacts inside the switch have failed and just no longer make contact when the switch is pulled all the way out on the other lamps. Clearly, they all operate but just not in each of the switch positions that they are supposed to.
So here is a guide that will help with checking the voltage on these wires:
I am attaching the wiring diagram below but if it were me, I would replace the switch and retest the operation.
Let me know if you have questions or what you find. Thanks
Feb 21, 2022 at 10:41 AM
MAMACOUCH1998
  • 5 POSTS
Thank you. I replaced the switch and it works perfect now!
Sep 9, 2022 at 9:39 AM
  • 110,248 POSTS
Thank you for the update. We are glad to know it's working again.
Take care and please feel free to come back anytime in the future.
Sep 11, 2022 at 1:24 PM
