intermittent loss of dash and interior lights
130,000 MILES • 2.5L • 6 CYL • 4WD • AUTOMATIC
PAPPY56
  • 6 POSTS
My granddaughter's car is experiencing the issue listed above that has progressed to affecting the radio as well .any clue would be appreciated.
Jan 17, 2020 at 12:28 PM
  • 110,248 POSTS
I just ran through schematics for the courtesy lights and instrumentation lights. They are all on separate grounds, so that isn't an issue. The radio is powered differently. When you say radio, are you referring the the lighting on the radio or the radio itself?
As far as the instrument panel and courtesy lights, the only common component is the panel light control switch that could affect the radio lighting, but not the actual radio.
Jan 17, 2020 at 2:52 PM
PAPPY56
  • 6 POSTS
thank you Joe . hmm, could be more than one thing going on. the radio cuts off not just the light .
Jan 17, 2020 at 8:47 PM
  • 110,248 POSTS
I don't see a link between the two. Start with the basics. Check to make sure the battery is fully charged, the terminals are clean and tight, and the alternator is properly charging. With today's vehicles, low voltage can cause all kinds of issues.
Here are a couple links you may find helpful:
I was always taught to start at the beginning with electrical issues. That's the battery. Do this just to confirm it isn't something simple.
Jan 18, 2020 at 8:52 AM
PAPPY56
  • 6 POSTS
i always do Joe. great advice though as often it will be simple. thanks and thanks Joe for the links.
Jan 19, 2020 at 1:16 AM
  • 110,248 POSTS
You are very welcome. Let me know what you find. I'm interested in knowing how the two are tying together.
Jan 19, 2020 at 11:18 AM
PAPPY56
  • 6 POSTS
i will be hopefully getting to that one the beginning of the week. if i don't find it, will take it to someone as funds allow for her. thanks
Jan 19, 2020 at 11:45 AM
  • 110,248 POSTS
Happy to help.
Jan 19, 2020 at 12:35 PM
