It will idle rough and shake. It misfires and sometimes will not go when I give it gas. I put new spark plugs and coils in it.
Mar 14, 2017 at 7:49 AM
HMAC300
✓Experienced Mechanic
you can check fuel pressure with a gauge as that will sometimes cause it as well as a vacuum leak. autoparts rent gauge you can also check for a vacuum leak and plug wires for resistance 5000 ohms per foot. but your cheapest option so you don't spend anymore money on good parts like you have is to have a mechanic scan for codes and check sensors and injectors as this could be the problem.
Mar 14, 2017 at 8:39 AM
RYANMP44
MEMBER
I already checked that it is all good. I scanned for codes and it shows a misfire code.
Mar 15, 2017 at 12:50 AM
HMAC300
I meant something other than a misfire code. but your cheapest option is to have a mechanic see what the problem is so he can read the sensors and bypass some if needed.
