Ignition problem
120,000 MILES • 1.0L • 3 CYL • 2WD • MANUAL
ROBIXS
Hi, I have one positive cable at ignition module when I turn engine in ignition on at spark coil I have positive in white cable. I do not have spark at the engine. Number of engine I see EJ the car can be start for only take three gear and push him and car ignition on and motor working but from key not working.
Nov 6, 2018 at 8:13 PM
  • 55,643 POSTS
Sorry not to sure what you are saying? The engine runs when you push start it? Can you hear the fuel pump in the tank running? Here is a guide to help us get started:
Cheers, Ken
Nov 8, 2018 at 4:01 AM
