1999 Daihatsu Sirion White smoke
BILLYWIZZIT
Engine Performance problem
1999 Daihatsu Sirion Two Wheel Drive Manual 63000 miles
Sirion 1.0L 3 cylinder. I have done a compression test on the engine all cylinders are equal in output 175.
I have also changed the valve stem oil seals but the engine pours out white smoke in the morning until it is warm. Any help out there
Sep 28, 2009 at 8:15 AM
  • 75,988 POSTS
Maybe its condensation if not could be coolant leaking into the cylinders due to blown headgasket, cracked head or block when the engine contracts.
When the engine start reaching its normal operating temperature this is where the leak seals iself due to metal expansion.
Or get it block and pressure tested
Sep 28, 2009 at 9:04 AM
