2002 Other Daihatsu Models catalytic converter exhaust
2002 DAIHATSU
JOHN COLLINS
Engine problem
2002 Other Daihatsu Models Engine Size unknown Two Wheel Drive Manual 110000 miles
My car will be driveing ok for a while then starts to miss loose power, there is a engine management light on well thats what i think it is, orange light
It is a Daihatsu YRV 3 cylinder
I put new plugs, New oil, oil filter, air filter and new set of o-rings on the injectors.
Jan 6, 2008 at 5:13 PM
  • 31,937 POSTS
Hi there,
You will have to get the code for the fault light read this will be the starting pace to get information as to you problem, if you can supply the code, i may be able to assist you. If you are not sure, contact your local mechanic and he will be able to extract the code for you.
Mark (mhpautos)
Jan 6, 2008 at 5:19 PM
