1999 Other Daihatsu Models coolant level
1999 DAIHATSU
78,000 MILES • 4 CYL • 2WD • MANUAL
BRADAWL
coolant level needs topping oftenno sign of a leek appears to overflow from resevior tank when engine is hot thanks temp gauge shows engine temp[ as right
Aug 8, 2010 at 12:18 AM
KHLOW2008
  • 41,812 POSTS
Hi bradawl,
Symptoms indicates the radiator cap is bad. It is not holding the pressure allowing coolant to move too freely between the radiator and recovery tank.
Aug 8, 2010 at 12:35 AM
