1996 Other Daihatsu Models nothing works
1996 DAIHATSU
9,656 MILES • 4 CYL • 4WD • MANUAL
SKIP818
new battery,but no horn ,no lightes,no wipers, nothing. is there a master fuse to check or am i missing something else. i have fire from battery to starter , but not at keyswitch
Sep 30, 2008 at 11:12 AM
WILLIAM TREDER
  • 5 POSTS
yes there certainly is, it's called the main fuse. should be biggest amp fuse in the whole car. you hooked it up backwards didn't you.
Jan 20, 2009 at 1:10 AM
