1998 Daihatsu Duet Engine Heating up
1998 DAIHATSU DUET
ALIIKHLAQ2006
Engine Cooling problem
1998 Daihatsu Duet Automatic
Hi i have a Duet car my engine get hots after a 20 min drive i get it to workshop he search the reson but he can not find i go to the 3 or 4 more workshop but no one finds the problem the radiator is ok no leakage water fllowing fine one of a mechanic open the engines 2 times but not find any problem all things working fine.
Jun 28, 2010 at 10:39 AM
Have them check the thermostat
Jun 28, 2010 at 12:06 PM
ALIIKHLAQ2006
yes i have check the thermostat some one give me suggestion that place double gas kit under the head is it rite to do
Jun 28, 2010 at 8:49 PM
MOHAMMAD ASAM
i am asam i read your problem r u sure 2 remove thermostatic expension valve installed in water cooling system.
Oct 9, 2012 at 7:10 AM
