1997 Daihatsu Charade fan belt tension specs
200,000 MILES • 4 CYL • FWD • MANUAL
DAN1976
Hi guys,great site.how do i measure the tension on the belts? i.e. how many mm(inch) play in each belt is needed? thanX. its the alternator &pwr steer belts.
Sep 17, 2009 at 11:26 PM
DAVE H
  • 13,383 POSTS
we do not have the spec's for this vehicle .. your locl autoparts store will supply a repair manual with the details you need inside
Aug 30, 2010 at 8:00 PM
