1993 Daihatsu Charade CHANGING HEAD GASKET, VALVE GRINDING
1993 DAIHATSU CHARADE
GUSMIF
Engine Mechanical problem
1993 Daihatsu Charade 4 cyl Front Wheel Drive Manual
Hi. I'm trying to change the head gasket/ do a valve grind on my daughter's 93 Charade. The only manual I could get my hands on was for a Charade up to April '93 (G100 G102 etc).
This car's engine is a CX G200, HC 1295 TC 16n valve EFI.
How different are the engines and will this manual suffice. If not, what are the differences I need to know about?
Thanks, Steve
Oct 4, 2008 at 5:06 PM
KHLOW2008
  • 41,814 POSTS
Hi gusmif,
Thank you for the donation.
If the Haynes manual is for a 4 cylinder engine, then it isuffices.
Basically there had been no changes to this engine since it was launched.
Oct 4, 2008 at 5:44 PM
