Request information on where to buy a fuel injector puller for this car.
I will replace all injectors. Is there a brand that I should purchase, Bosch etc.?
The car has a miss at idle, low RPM and at hwy RPM.
Give more throttle when miss happens, miss is softened.
Changed out the dist. cap, rotor, wires and spark plugs, these were needed. # 2 cyl, is leaner than other cyl.
Other tests?
I am a Coast Guard electrician, Retired.
Thank you for your time,
Mike
PS. How do I donate.
Other tests?
Mike
Dec 24, 2009 at 7:26 AM
