Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Daihatsu
Charade
Electrical
Battery
Charge
1992 Daihatsu Charade Battery charging
1992 DAIHATSU CHARADE
80,000 MILES • 4 CYL • 2WD • MANUAL
PANDIOK
MEMBER
1 POST
How to charge the battery from flat with the engine running
Oct 10, 2008 at 10:54 PM
Experienced Mechanic
Hi there,
you should never try this a s you can do expensive damage to the ECU if you get a voltage spike.
Mark (mhpautos)
Oct 10, 2008 at 11:04 PM
Add image or video
Ask a new question
Engine overheating
Engine won't start
