Engine Cooling problem
1985 Daihatsu Charade Front Wheel Drive Manual 114000 Km
I have changed the thermostat, changed the radiator cap and fixed a small leak in the radiator. However, my car has decided that it is not satisfied and still wants to over heat. i am thinking it is the water pump. would i bt correct in this assumption? or would it be something else?
Dec 6, 2009 at 11:26 AM
