1984 Daihatsu Charade Hi, PRO...
1984 DAIHATSU CHARADE
FREDUMS
Engine Cooling problem
1984 Daihatsu Charade Two Wheel Drive Manual
I've just start my car for a few minute and it become hot. what is the possible problem ang your suggestion solution for this?
Nov 13, 2008 at 5:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
From easiest and cheapest to more costly and difficult;
Low coolant level, faulty thermostat, loose/worn water pump belt, faulty water pump.
Check coolant level then repost your results. I will follow up.
Nov 13, 2008 at 5:57 PM
ANDREW CORNFORD
[quote:d73580de8d="fredums"]Engine Cooling problem
I've just start my car for a few minute and it become hot. what is the possible problem ang your suggestion solution for this?[/quote:d73580de8d]
G'day there,
I have the same problem. sorry but I don't have a cure for your problem, I'm just wondering if you heard back from anyone else so you can assist me.
ACE.
Aug 16, 2009 at 1:20 PM
