2002 Other Daewoo Models performance query
2002 DAEWOO
65,500 MILES • 4 CYL • 2WD • MANUAL
LOCOTT
we have had the car for 6 months, it has always been serviced. But it burns alot of oil - needs to be topped up every month or so depending on mileage, or becomes tappy - it is not leaking oil.
Also the engine is very 'farty' and has problems especially in 4th gear up hill.
The braking is also questionable, causing a shaking sensation through the steering wheel when braking gently from high speed. When brakes are applied firmly, this does not happen. the car does not pull on braking, and the hubs are not hot to the touch after driving.
any ideas on what could be the cause of both would be gratefully received.
many thanks.
Aug 12, 2009 at 6:10 AM
DOCFIXIT
  • 18,828 POSTS
Valve stem seals and rings is oil consumption and warped front rotors is shake
Aug 12, 2009 at 6:22 AM
LOCOTT
Wow! Thank you so much for the speedy response!. How much roughly am I looking at to get this sorted at a garage...and what exactly are the front rotors ? (woman here) :)
Aug 12, 2009 at 6:25 AM
DOCFIXIT
  • 18,828 POSTS
Valve seals @ $400 rings 2$1000 shop will need to determine which is needed. Also check air filter if oily locate PCV valve that may be cloged and will suck oil out of engine. Rotors are the hubs that brakes apply to to stop car. May just need truing @ $175
Aug 12, 2009 at 6:44 AM
