1995 Other Daewoo Models
1995 DAEWOO
KINDMAN78
Engine Performance problem
1995 Other Daewoo Models 4 cyl Two Wheel Drive Manual
HELLO DEARS
I HAVE DAEWOO PRINCE 1995
MY CAR HAS MISFIRE WHEN THE WEATHER IS HOT (MID-DAY) BUT IT IS OK WHEN THE WEATHER IS COLD ESPECIALLY IN THE MORNING .I CHANGE FUEL FILTER , I TEST THE SPARK PLUS ONE BY ONE IN ALL COIL, I CHANGE AIR FILTER AND CHANGE THE FUEL PUMP TOO , BUT THE PROBLEM IS SAME .
AND SOMETIMES IT RUNS WITH HESITATION , OTHER TIMES RUN NORMALLY AND AFTER A WHILE GETS HESITATION .
PLS ANY SOLUTION FOR MY PROBLEM
Oct 24, 2008 at 9:12 PM
  • 31,937 POSTS
HI there,
i would do a scan and check foe a faulty cam or crank shaft sensor, the crankshaft sensors are a problem on these cars.
mark (mhpautos)
Oct 24, 2008 at 9:17 PM
