2002 Daewoo Nubira Losing coolant
INGA11
Engine Cooling problem
2002 Daewoo Nubira Automatic 62000 miles
hi my nubira 2002 is loosing coolant all the time. There are no leaking under the car, the fans come on as it heats up, we have had the water pressurechecked and it is ok and as a precaution we changed the radiator cap. Other service seems ok dirty spark plugs replaced and the car has don 62000km. Though mechanic says there is the chance someone has turned back the KMs. Gratefull for any help Inga
Nov 9, 2009 at 10:47 AM
  • 75,988 POSTS
Are you overheating? Could be leaking into the cylinders, oil pan or the transmission
Nov 9, 2009 at 10:52 AM
