2001 Daewoo Nubira Valves
DANIELJONES1
  • 8 POSTS
Engine Mechanical problem
2001 Daewoo Nubira 4 cyl Front Wheel Drive Automatic 80 000 miles
The timing belt snapped and resulted in no compression from cylinder #3. So I assume I have bent some valves. I figure it's just easier to replace them than get them ground. Is this correct? Can I just buy them off Ebay where they are advertised or is this generally unsuccessful? Where should I buy them? (This car is no longer manufactured so parts are difficult to come by)
Oct 8, 2009 at 6:56 AM
DAVE H
  • 13,383 POSTS
the valves will have bent .. so repalcement will be necassary ,, ebay is a good place to start also contact your local part stores .. they should be able to locate valves for you
Mar 17, 2010 at 1:53 AM
