2001 Daewoo Nubira timing
SUNSEEKER121
Engine Mechanical problem
2001 Daewoo Nubira 4 cyl Front Wheel Drive Manual
Hi I have just replaced the timing belt and have lined up the timing marks as shown elsewhere on this site, but the motor is back firing through the carbie and of course is not running, any ideas as to why and what the solution may be.
Thanks
Brian
May 29, 2010 at 7:36 PM
  • 31,937 POSTS
Hi there,
If you are sure thats the valve timing is correct, just check thats you have to crossed a plug lead, this sis easily done if you had them off.
mark (mhpautos)
May 30, 2010 at 12:44 AM
