2001 Daewoo Nubira Heater Blower
2001 DAEWOO NUBIRA
139,000 MILES • 4 CYL • FWD • AUTOMATIC
BRADYBA
My heater blower was working fine yesterday. This morn. is started car. no heater blower. I tried and tried to get it to come on. No luck. A little later my boyfriend went out to see what was wrong with it, it turned on fine and worked fine. Shut it off. Then waited for a while . Started car again. No heater blower. Do you know what the problem could be. It works only sporadically
Jan 5, 2010 at 2:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check blower motor relay. if OK suspect faulty blower motor resistor or blower motor. will have to test both
Jan 5, 2010 at 5:20 AM
