2001 Daewoo Nubira Engine runs But Automatic transmission f
50,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBERT.ROOK
Car driven to carp park, all normal, on attempting to leave car park engine runs normally but the Automatic Transmission fails to engage in any gear R/D/1/2/3/. Gearshift moves normally- quadrant in engine compartment moves in synch with gear lever.
ODB codes are
P0342
P0342P
P1810P
even after reset.
Jul 19, 2008 at 7:13 AM
DOCFIXIT
  • 18,828 POSTS
The 342 is Camshaft position sensor
342p and 1810p manufacture codes.
1810 indicates trans fluid press valve that one will keep trany in neutral no fluid will flow in trans. It is in the valve body pan and body need to be removed.
Jul 19, 2008 at 7:33 AM
