2001 Daewoo Nubira Crankshaft puley
12,200 MILES • 4 CYL • FWD • AUTOMATIC
BRADYBA
I have a squeeling in my car and someone said it was like a crankshaft pulley that need to be replaced. is there such a thing and doe that sound like the problem. It isn't a belt, we know that.
Apr 15, 2009 at 10:13 AM
  • 31,937 POSTS
HI there,
The pulley you are talking about is the front crank shaft pulley, i doubt that this is your problem, i would remove all the belts and run the engine if the noise is still there it may be a timing belt problem, if gone, replace belts one at at time and run to see which is at fault.
mark (mhpautos)
Apr 16, 2009 at 1:50 AM
