2000 Daewoo Nubira TRANSMISSION DOESN'T SHIFT
67,020 MILES • 4 CYL • 2WD • AUTOMATIC
STAN KRAUSE
THANK YOU FOR YOUR HELP WELL THE OBD II CODE-
1810---- ATF PREMIUM MANUAL VALUE POSITION SWITCH MALFUNCTION.
AND
741---- TORQUE CONVERTER CLUTCH SOLENOID CIRCUIT PERFORMANCE OR STUCK OFF
THIS IS A GENERAL MOTORS BUILD ENGINE BUILT IN AUSTRALIA. PORSHE ENGINEERED
WHAT IS THIS ? WHAT CAUSES THIS OR WHAT IS THE SOLUTION TO FI.X
Oct 17, 2008 at 8:35 PM
  • 55,658 POSTS
Hi, the two trans codes are pointing to a transmission failure, either the torque convert is coming apart or the control solenoid is bad. Remove the pan to inspect the fluid, if burnt the trans sound like it needs replacing.
Nov 10, 2008 at 9:17 AM
