2000 Daewoo Nubira timing belt
75,000 MILES • 4 CYL • FWD • AUTOMATIC
JUFRANCO
I just change the water pump (driven by timing belt)
and the car doesn't start. Looks like a fire problem. Everything is well alling, the belt turn by hands and the compression is good on all 4 cylinders.
Nov 27, 2008 at 11:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Ensure that crankshaft and camshaft marks are aligned.
Also make sure belt is tight and tensioner is aligned with notch on rear timing belt cover.
Nov 27, 2008 at 4:14 PM
