Have 2 check engine lights P0342 and P0717, question, is there a cheap fix?
Nov 10, 2010 at 7:50 AM
BLUELIGHTNIN6
✓Experienced Mechanic
DTC P0342 : Cam Position No Signal
DTC p0717 : Input Speed Sensor No Signal
If both of these appeared at once then could be due to faulty PCM . Also check wiring at the cam sensor and speed sensor. If PCM and wiring is good then the sensors themselves may be at fault
