WHERE IS THE KNOCKING SENSOR LOCATED AND HOW DO I CHANG IT?
Sep 29, 2009 at 3:21 PM
DAVE H
✓Experienced Mechanic
Disconnect negative battery cable. Remove intake manifold. Disconnect electrical connector at Knock Sensor (KS) Remove (KS).
Install KS. Tighten knock sensor bolt to 15 ft. lbs. (20 N.m). Connect electrical connector at KS. Install intake manifold. Connect negative battery cable.
Apr 10, 2010 at 11:55 PM
