1999 Daewoo Nubira p0452
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
PITO2169
  • 5 POSTS
im getting this code and would like to know how to diagnose exactly whats wrong with it with out buying un nesscary parts.. thank for time and patience
Mar 10, 2009 at 2:35 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
Code P0452 indicates Fuel Tank Pressure Sensor Low Voltage. Most possible cause is a faulty sensor itself but the wiring may also be at fault. Inspect wiring and if OK suspect faulty fuel tank pressure sensor.
Thanks for using 2CarPros.com!
Mar 10, 2009 at 3:14 PM
