1999 Daewoo Nubira oil pmup
147,000 MILES • 4 CYL • FWD • AUTOMATIC
DANIELDAVISBIKER
The oil pump is leaking on my car. I have it pulled and I Was reading in my manual that it says to pack the oil pump with petroleum jelly for proper priming. My question is, Is there a o-ring on the back cover so that I can pack the oil pump with the petroleum jelly? I can't find any parts breakdown for the oil pump and finding parts for the car are difficult. I want it to be done correctly. I thought that it would self prime, so I want as much information so that I can get my car running again. Thankyou
May 30, 2010 at 3:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you pack the oil pump with petroleum jelly in the gear cavity of the pump.
May 30, 2010 at 3:46 PM
DANIELDAVISBIKER
so I don't have to remove the rear cover of the pump, just in the opening of the pump should be fine?
May 30, 2010 at 3:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes correct
May 30, 2010 at 3:55 PM
DANIELDAVISBIKER
thank you for responding so quickly. I will pack where the pick up tube goes until I can't get anymore petroleum jelly in.
May 30, 2010 at 3:59 PM
