1999 Daewoo Nubira BRAKING
GAZZER2008
Brakes problem
1999 Daewoo Nubira 4 cyl Two Wheel Drive Manual
HI I HAVE A PROBLEM WITH MY BRAKES.
EVERYTIME A TRY TO BRAKE I GET A LOT OF PULSATING AND GRINDING ON THE BRAKE PEDAL.
I WAS TOLD I HAD WARPED DISCS SO I RENEWED THE DISCS AND PADS EVEN BLEED THE SYSTEM BUT THE PROBLEM STILL REMAINS CAN ANYONE PLEASE HELP ME AS I HAVENT A CLUE ANYMORE
MANY THANKS
May 21, 2008 at 8:52 AM
  • 31,937 POSTS
Hi there,
You will have to inspect all the brakes , it sound as if you may have installed a pad back to front, if there is a bad grinding noise when braking, you will see what is wrong when you remove the pads.
Do this first.
Mark (mhpautos)
May 21, 2008 at 12:37 PM
UBOI
could just be your rims and tire..???
Jan 19, 2010 at 12:48 PM
