2004 Daewoo Leganza wheels
2004 DAEWOO LEGANZA
102,000 MILES • 4 CYL • FWD • AUTOMATIC
DAYLON GULLAGE
I would like to put some wheels on this car but the lugs holes does not match so what kind of adaptors would I need
Aug 23, 2008 at 8:21 AM
YOBOBYO
  • 17 POSTS
I don't know about you, but the way the front suspension is set up on this car, I wouldn't try and put wheels that don't fit. Understand that in order to change the lug pattern you have to put some kind of adaptors/spacer. This will move the wheels out as much as an inch to an inch and a half depending on the adaptors/spacer. This alone will put extra wear on the wheel bearings. And if you put the 205x60x15 tires that come on the car, you take a chance of them rubbing on the inside of the wheel well. Check everything before buying and installing these wheels and tires.
Again this is not advised!!
You can buy these spacer at Pep Boys or any wheel shop.
Robert
Oct 7, 2008 at 5:56 PM
