2002 Daewoo Leganza only 2 sparks in 2 cylinders
2002 DAEWOO LEGANZA
HVPTECH
Engine Mechanical problem
2002 Daewoo Leganza 4 cyl Two Wheel Drive Automatic
hi, my car is running on 2 spark plugs, i have changed the igntion coil 3 times, i have changed spark plugs and leads, still same problem,. i have tested with fault code reader to show as p0352, i dont understand plz help, local garage told me might be cam sensor but its not showing that on fault code reader
thanks
Apr 1, 2009 at 1:51 AM
DAVE H
  • 13,384 POSTS
check and clean the CAM and CRANK sensors !!
Apr 7, 2009 at 12:45 PM
