2002 Daewoo Leganza belt placement
SUPERFREAK2007
Engine problem
2002 Daewoo Leganza 4 cyl Wheel Drive Type unknown Automatic 90000 miles
I am having trouble finding any info about belt placement can you please send me a diagram on what belt placement is for a 2002 Daewoo Leganza with a 2.2 engine
Jan 30, 2008 at 9:16 AM
YOBOBYO
  • 17 POSTS
On this car, you only have (2) belts.
1) is a serpentine belt witch is driven by the crank and turns your alter, power steering, and air.
2) is the timing belt.
These both should be changed every 55,000 to 60,000 miles. As far as the timing belt,, if you don't change it on time, it will break, and it will cost more then the car is worth to fix. I haven't seen this belt last more the 70,000 miles before it brakes.
A little advise,, Change the water pump and bearings while they have it apart.
Hope this info wasn't to late to help.
Let me know
Robert
Oct 20, 2008 at 10:24 AM
