2001 Daewoo Leganza what is the fuel pressure specs suppose
2001 DAEWOO LEGANZA
THERESA1212
Engine Performance problem
2001 Daewoo Leganza 4 cyl Automatic 84,000 miles
my car was running shitty and kept stalling out and it was real rough sounding so i changed the fuel pump and filter which had alot of rust in the tank and a lott in the filter as well Anyways it still will not stay started so i was wondering if u knew what the fuel pressure specs is supposed to be or any other suggestions of what else it could be i will donate as soon as i get my car home it is being towed here now cause it still won't run and my credit card is in the glove box please help me i promise i will donate as soon as it gets here
Jan 31, 2009 at 1:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
30 - 45 psi is what should be at the rail when you turn the key to on (engine off). Also inspect the spark at the plugs. Make sure all plugs are receiving a bright blue spark.
Let me know the results of fuel pressure test and spark and I will follow up.
Thanks for using 2CarPros.com!
Jan 31, 2009 at 1:20 PM
