2001 Daewoo Leganza camshafsensor location
SARAHDOUG
Engine Performance problem
2001 Daewoo Leganza 4 cyl Two Wheel Drive Automatic
i need to know the location of the camshaft sensor
Apr 20, 2008 at 3:56 AM
BEEFY
If you look on top of the engine towards where the belts are you will see a wire running underneath the beauty cover. When you remove that cover the sensor is right there on in the valve cover right next too the timing belt. TO get to it you haveto take the valve cover off.
May 1, 2008 at 6:26 PM
