2000 Daewoo Leganza Leaking antifreeze
2000 DAEWOO LEGANZA
10,000 MILES • 4 CYL • FWD • AUTOMATIC
BRONCOSKICKASS68
It started leaking antifreeze on the back of the block under the intake. It is very difficult to see the water pump and the hoses run every where. I have no manuals as they seem impossible to find. Could this be a water pump? There is no antifreeze in the oil, and it looks like the only way to fix this problem is from underneath. Am I going in the right direction? is this simple and inexpensive?
Oct 7, 2008 at 12:13 PM
BLACKOP555
  • 10,386 POSTS
water pump is turned by the drivebelt it has a larger circular pulley. and has coolant hoses going to it.
its on the side with the serpentine belt.
can you get a picture of where the leak is or get back there to see it?
Oct 7, 2008 at 12:42 PM
