2000 Daewoo Leganza Flasher Relays
BURRDANE83
Electrical problem
2000 Daewoo Leganza 4 cyl Automatic
I need to know where and which ones they are.
Aug 28, 2008 at 11:00 AM
YOBOBYO
  • 17 POSTS
Hello,,
If your looking for the blinker/flasher relay, it's under the driverside dash. behide the main fuse box.
If you put you head all the way under the drivers side part of the dash, then look just behide the main fuse box. you'll see five or so relays. looking at them you'll see 2 gray then a black, then a green, then to the side of that one another gray. The flasher/blinker is the green one. To get it out, Don't rip it, just work it, it should just pull right out. The part number is 96312545.
Hope this message wasn't to late.
Let me know if it work for you..
Robert
Oct 20, 2008 at 9:55 AM
