2000 Daewoo Leganza Emergency Brake
2000 DAEWOO LEGANZA
99,000 MILES • 4 CYL • 2WD • MANUAL
FUDDSGAL
When I apply the emergency brake the car still moves. I adjusted the cable under the center console and that just made it more difficult to raise the lever. What needs to be repaired in order to stop the car from rolling when I am parked, as the brakes work while driving?
May 15, 2008 at 3:26 PM
  • 31,937 POSTS
Hi there,
i would be checking for a seized cable or a binding hand brake actuator at the rear brakes.
Mark (mhpautos)
May 16, 2008 at 12:05 AM
BOBBYTECH1
  • 49 POSTS
the reason for your parking brake not to work is your adjuster in side the rear rotor needs to free up and adjusted, you hav to remove your rear rotors in order to do this task
Jun 29, 2008 at 5:12 AM
