2000 Daewoo Leganza Car won't shift gears...
2000 DAEWOO LEGANZA
CYZARK
Transmission problem
2000 Daewoo Leganza Four Wheel Drive Automatic 89000 miles
I was driving my 2000 Daewoo Leganza and stop at a light, as the light turned green I stepped on the gas and their wasn't any movement from my vehicle, the RPM's were increased but still no acceleration. I turned the car off and quickly turned it back on and tried again and it drove for about 30 yards and continued to rev up the RPM's again. What is wrong with my car, I changed the spark plugs and valve cover gasket to clear up an oil leak but the problem still exist... PLEASE HELP, THANKS.
Sep 10, 2010 at 7:32 AM
Sounds like your transmission is slipping bad-if not check the throttle position and manifold absolute pressure sensors-
Sep 10, 2010 at 8:49 AM
