I've replaced the shoes and turned the rotors, bled the brakes. The only thing was I might of let the master run low on fluid. But I've filled it, and bled all the old fluid out. As of now, I might have 30% to 40% of the brake power this car once had. I don't want to keep replacing parts. I've also replaced the master, and booster with no change. The pedal is soft but doesn't go to the floor. In the manual, it states something about if the ABS system were to get an air bubble you have to have the dealer bleed the air out with there ABS scanner. Is this true? or is there another way to do it.
Oct 6, 2008 at 7:18 PM
