1999 Daewoo Leganza fuel shut off switch
RCRUSENBERRY
Electrical problem
1999 Daewoo Leganza 4 cyl
The car will start while being primed, and then cut off. The fuel saftey shut off fwitch that was located beside the passenger seat when it was disconnected it has a rattle inside as if it has been broken. I just bought the car from the auction and need some help getting it to run. No history of the car was given, and I'mlooking for a inexpensive manual, and someone that carries a fuel shut off switch reasonablly. Thank You, Rebecca
Oct 14, 2008 at 6:48 AM
YOBOBYO
  • 17 POSTS
I'm not 100% but I think that is what that switch by the passenger seat should do. If you were to get in a reck, the ball inside moves shutting off the fuel.
First thing is, Does the fuel pump kick in when you first turn the key just before you start it? If it does, your getting power to the pump. and it's not the switch or the relay. Check the fuel filter, you'll find it on the back fire wall. That could be an easy fix. If you don't hear any thing from the fuel pump, try checking your fuel relay. You'll find it under the hood, by the battery. Open the fuse box and look on the top of the lid and it will tell you witch one it is. Istead of going out and buying one, remove the one for the air conditioning.. and trade them out,, see if that will work.. You don't have to start the car, as soon as you turn the key, you should hear the fuel pump kick in. If it does just replace the relay.
Good luck.
Robert
Oct 19, 2008 at 1:50 AM
