1999 Daewoo Leganza fuel guage wont go down
1999 DAEWOO LEGANZA
TARIKEONU
Electrical problem
1999 Daewoo Leganza 4 cyl Front Wheel Drive 85000 miles
hello from ny, i took my car to repair shop check battery because battery go down if i park my car for week wont start what he did he used extra cable to groud conected to enzine body. after that all the gauge went up enzine guage came down but fuel gauge not now i dont know how much fuel i have in my car.i told the guy u made a mistake he said it has nothing to do with fuel. please answear me thank you so much.
Sep 14, 2008 at 10:11 PM
YOBOBYO
  • 17 POSTS
Check the recall on your car, Daewoo leganza's have had a problem with the gas gauge not showing the right amount due to some faulty wiring. At one time the dealer were taking care of this for free.
If they won't,, you'll have to do it your self or find someone that can do it for you, Cost,, somewhere around $200.00 to $300.00 bucks. Understand, the sensor is in the gas tank. You can get to it by removing the back seat. (You don't have to drop the tank!!!) Under it you will see a black cover, remove it. You should see the top of the fuel pump and the wiring for it. Disconnect the fuel lines and wiring. Then slide the ring clip, this will free up the unit, and you will be able to pull the fuel pump and sensor out of the tank. At this time check everything. Make sure there wasn't anything that might of kept the float from moving freely up and down. Daewoo does have a part so you can just replace the sensor instead of the fuel pump and sensor. That can save you a few bucks. Once this is done, just put everything back together as you took it apart, and you should be ready to go.
Hope this helped you out,,
Robert
Oct 7, 2008 at 2:22 AM
