1999 Daewoo Leganza code PO 337
71,000 MILES • 4 CYL • 2WD • AUTOMATIC
ONEVICIOUS
My Car will crank but will not start. Code reader returns "PO 337 crankshaft position sensor low input." I have changed the crankshaft position sensor. car still will not start.
Aug 24, 2010 at 3:51 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Is there voltage to injectors? coli? do you have spark at plugs? is there fuel pressure?
Let me know
Thanks for donate
do you have a DVOM?
Aug 24, 2010 at 5:06 AM
ONEVICIOUS
There is Voltage at injectors, coil, and no spark at spark plugs. and there is fuel pressure.
Aug 24, 2010 at 6:33 AM
DOCFIXIT
  • 18,828 POSTS
Voltage at coil on white and orange wires? put test light on black wire at coil put clip on POS crank does it flash. if you have DVOM place on 2 V AC scale unplug crank sensor place meter on two wires with color. Crank does it show voltage?
Aug 24, 2010 at 6:41 AM
PICARD144
I am having the sam problem but no flash on black wire on coil!
Jan 18, 2016 at 4:36 AM
